- Aug 25, 2008
Do NOT bend the lockbar. The problem is and was stated above that the ti lockbar has worn from when it was new. Send it in to Strider and let them fix it. Most likely they will fix it by replacing the stop pin with a slightly larger diameter which will result in earlier lockup. I've used Strider's CS with my SnG and I got it back in like 2-3 weeks and the knife was better than new.
If you send it in make sure you leave a note with the problem and your contact info. If you need to contact the shop this is the only method that WILL give you results : heather@striderknives.com Send the knife with $15 for return shipping and wait.
Exactly. Thank you. If my little test helps then this is your problem and you need to send it it. So they can put a cap on it.
