- Dec 2, 2005
They're called needle files here. I see knives like this quite regularly. I've even had knives with blades that are practically at a 45 degree angle! Flaw or not, it's something I personally detest.
Hi Sarah! Thanks for the pics. Good to know I'm not the only one bugged by this "characteristic". Looks like I might just have to break out the small files and have a go at it. Mine is after all a not-very-expensive user knife so I'm not afraid of marring it. And I do love to tinker so this might be an ideal project.
Linus
Looks like the back spring or the notch on the tang is too long. File the spine of the blade where it contacts the back spring and that should take care of it.
Seems like this was suggested to you in the 2nd post.
Your point being?
As I said above, I get the OP's point and Mike's point but once the material is removed from the tang in order to make the blade spine parallel with the spring, it will still be underbladed, at least in the case of the OP's knife and most others where the blade starts out not being parallel with the spring.
