David Martin
Moderator
- Apr 7, 2008
Ok, good. I'm glad you learned something. DM
Not trying to take over the thread, but I just received a 500 and 503 yesterday new directly from Buck. They were both the same way. Very disappointing. I don't know whether to send them back for repair, exchange, or return them altogether, especially if they are going to send them back in the same condition. I don't have the tools to repair it myself. Any thoughts or advice would be greatly appreciated.
When the 500 series first came out(in the 70's) I bought one of each and none of mine has this protruding lock-bar. Even later on the Duke. No raised lock bar. So, it must be more recent. Anyway an easy fix, should it be of concern. DM
I think it has more to do with the tab on the lockbar, or perhaps the blade tang section where the lockbar tab rests when the blade is closed.I wonder why the bar sticks up on some and not others. Maybe certain bars that they install aren't perfectly concave and aren't perfectly fitted for the knife.
If I send these back to Buck, and explain my concerns (perhaps over the phone), do you think it will be fixed? I hate to sand on brand new knives unless I had no other choice. Not knocking Buck because I love their knives and the company, but I fear that their quality control has declined. I didn't use to have these problems when I opened a new Buck knife.
If you decided to send your knife/knives back to Buck for a possible repair, there's an area of the online form on the Buck website where you explain your problem with the knife. You can leave your phone number, and maybe make a note to have them call you when they get to looking at your knife. If the knife is unrepairable, they might give you the option of exchanging it for another. I took matters into my own hands because I sent the same knife in twice, once for centering issue and the other was for the lock bar exposed, and I didn't want to spend more money and time on sending it back a third time. Not sure if they can fix the lock bar being exposed a little, because I got my knife back from them the same way I sent it out.
It's funny, I feel a real connection with my 501 after doing some of the custom work myself. It's like you bond with the knife.![]()
I think the exposed lockbar is a harder fix than centering etc.... The lockbar pivot pin is hidden under the scales, so that would require removing the scales to get to it.
I'm guessing that as time went on they removed or drastically shortened the step of the process where that protruding section gets fixed. Everybody is cutting corners and the "Made in the USA" stuff is under the most pressure. So what was standard on all knives years ago may be "custom shop only" on selected knives today.
