Some peeps get this^ and some simply never get it.
rolf
He says that he'll carry it for a few days to see if the lock loosens. I'll probably even out the scales if he so desires. The edge isn't a big deal either as he can just sharpen to how he wants.
I have never owned or used or even held an Emerson. I have been thinking about one cause I like chisel grind and 100% USA made. That said, for approx $300 the fit and finish from those pics is a bit disappointing. If a person can afford 3 bills a little more gets a sebenza. A $60 USA kershaw typically has better quality finish look. I would have to guess almost half the cost is essentially brand name.
Until you hold, or use one, you'll never know.
I only use WD-40 to flush junk out and then use compressed air. Never needed lube with them, plus I feel lube just attracts crud. My CQC-8 is as smooth as glass and the lock is flawless.
But, yeah...Emersons need to be broken in. Just the way they are made. And yes the fit and finish could be better, but the ones I have owned have always been 100% serviceable. They have a human made feeling to them, which I appreciate.
Honeslty WD is a horrible lubricant because the "wd" stands for water displacer, and if you have moisture in the inner working of a knife, firearm, or in the case of black powder firearms. The wd set on top of the moisture, or black powder residue. Than you can get rust.
There are many good lubricants from just olive oil, clp, 3-1 oil or frog lube just to name a few that will penetrate and lude the metal with a light coat of oil. Some of the better lube have ptfe aka teflon in that that work great.
Threw out my WD-40 years ago, and don't want any part of that after a very good friend use it to lub a muzzleloading rifle barrel, and the stuff left a coat of runt behind.
Please re read my post. I only use WD-40 to flush out my knives and then blow out any excess. I do not use lubes on my Emersons. They do not need it.
I do what Emerson suggests....figure he knows his knives better then anyone.
http://emersonknives.com/ek_faq/how-do-i-clean-the-knife
I am just not a WD-40 fan, and it is a very old product. Honesly they are some many surper duper lubes on the make today it is hard to choose a best one. I ever once in a while get a sample of some new lube product at a gun show, or prepper show.
So I have what might be considered a life time supply. I bought FrogLube a few year back and find it one of the better products. I purchuse a small jar for like 9 or 10 bucks, and it is still 3/4th. full.
