I have a 400 and 600 cork belt that I've used before. 2 questions. Do you finish your flats horizontally? You said preloaded cork belts but I'm not sure what I have so , do you load them with compound or not? Thanks for the replies fellas.
I finish my flats horizontal most of the time, although I do go all vertical on some kitchen blades from time to time, especially if the ricasso is narrow compared to the blade, or if the flats are non-existent or close to it.
There are two types of cork, those pre-loaded with their own abrasive, and those that are just cork, and you have to add compound.
I have also heard some that use compound,
with the pre-loaded belts, but I don't like the compound period, it kind of kills the whole beauty of the cork for me, which is they get "soft and dusty" when well dressed, and give a nice uniform finish without any burnished/overheated areas.
I've never tried the cork belts, but from what I'm hearing, they are great, and sound right up my alley.
If you're still willing to stick with the SB belt for awhile, I'd kinda ditch the thought of using them in a progression. I think scotchbrites should come after your final regular belt grit. Here's my formula. People may think this is lazy, or too rough etc, but I make working knives. I learned this from a well respected and very talented maker years ago:
60 grit ceramic
180 grit (A100) Gator.
Fine dark green scotchbrite loaded with WD40.
Thats it. Your grinds and flats have to be dead on though, which is why I suggested the Dykem trick.
You are one of the ones I was thinking of when I said some do great work with scotchbrite... they can be terrific if put to proper use, but just like cork belts, they do have limitations.
I personally think you would go bananas over a properly dressed 220g cork.
hello
This is 100% a belt finish:
^220 grit
I like Scotchbrite, but I don't fool with it much anymore. A clean belt finish is pretty straight forward.
If I had unlimited money, I'd probably finish most knives with a brand new J-flex for each bevel. Traditional style abrasives have been around forever for good reason.
