Is this what you buff a knife with?
That is a bench grinder set up as a buffer and the guy is pretty much doing EVERYTHING wrong. He is lucky that he is using a low horsepower model or he would probably be missing a couple of fingers and toes and maybe an eye or a gall bladder.:D
You also really shouldn't mix different compounds on the same wheel. Not if you want really good results anyway. It's best to have different wheels for different compounds. You can clean and load a more abrasive grit onto a finer grit but not vice versa.
An amateur using makeshift tools in all the wrong ways. Youtube makes you an instant expert!
About 20% of his information is correct. 80% is WRONG!
If you want to learn to polish, ask. Polishing is a craft that takes a lot of time, effort, and equipment to learn properly. It's better to just use sandpaper than attempt to polish the way this guy is doing it.
Agreed. I'm not even sure that he should have guns after watching that.
How should you properly polish a blade? Telling us how wrong he is, isn't helping anything. Post a link at the least.
There are many ways to properly polish. I'm sure the guy in the video was trying to be helpful, but following his advice would be sheer folly.
Here are a few things that are wrong:
The buffer should be securely mounted-not held in place by (appropriately enough) a dumbell!
Buffing AWAY from you does not allow you to see the progress, and it's not particularly safer.
Never mix compounds on a buffing wheel. You can only go from finer grit to heavier-never the opposite.
The guy is careless around the buffer.
You can't polish a large surface properly with a Dremel.
I don't remember him using safety glasses or a dust mask.
He was throwing buffing compounds all over the shotgun.
I only watched 2/3 of the video.
i started it up and almost could not finish watching it as i was just expecting him to hurt him self. buffers on a bench scare me as something could get caught between the bench top and the wheel and throw it. and it the case here it would shoot it right at you. a buffer on a pedestal is the way to go with the wheel rotating twords you so any thing will go down to the floor.
I was just waiting for that blade tip to catch...
That was painful to watch on many levels.
Two words: TRI POD
I didn't even watch the whole video, I clicked ahead and when I saw the one handed buffing the 10" chef knife I shot beer out my nose and exited.
When he turns the buffer off you can see it is spinning away from him. Either way it is 100% not proper form.
I have 2 buffers 1 is for metal one green and one white polish . The other buffer I use for wood one brown and one with nothing just to buff off and brighten it all up. I have another buffer I use for sharpening.
I have tried to stay away from these types of threads, but I am going to make a single insert into this one.
At no time, under any circumstances, should you ever polish on the top of the wheel with it turning away from you. This is just plain dumb, and if the buffer was an industrial size unit, might get you killed. You buff with the wheel turning downward , and buff on the area from 3 o'clock to 5 o'clock. Small bench grinders can be used to buff knives, but they only can support small buffs, and are low powered. To properly polish a blade you need a 10-12" buffing wheel turning at 1000 to 1500 RPM. Slower is often needed for handle buffing to avoid scorching the wood. Guards and work rests on a knife buffer are dangerous.
Never buff a sharp knife! this should be obvious, but there are those who sharpen the knife, or notice a scratch they missed, and take it to the buffer. This is good for hand surgeons, but bad for knife makers. The only time a sharp knife is put to the buffer is to buff off the wire...and there are many safer ways to do that. If you find you have to buff a sharpened knife, dull the edge, after the buffing, re-sharpen it.
You can build a good buffer with an 3/4" arbor shaft and some buffing wheels. Use 3" steel discs to support the sides of the buffs ( this will greatly improve the stiffness of the buff). Drive it with a 1/2 to 3/4 HP motor ,using a multi-pulley on the arbor. Use a pulley on the motor that will make the highest speed 1500 RPM.
Mount this on a stand or base that has the buffs in clear air. Never use a knife buffer on a counter, or with any surface closer than 24" below, above, or behind it. Stand firmly in front of the buffer ( not to one side), with your feet spread apart a bit. This is called a foundation stance, and you have much more control over your hands and arms. Turn on the buffer, and allow it to come up to speed. Apply the buffing compound sparingly, but often. Avoid loading the wheel up ( glued on grits are different). Bring the blade up to the buff in a upward arc, anticipating the grab when the wheels fibers abrade the blade. You want to be working in the 3-5 o'clock area.....never any other place. Apply moderate pressure, remember, buffing is polishing, not grinding ( you should have sanded the blade to a smooth and scratchless finish before buffing.). Avoid heat buildup, you can ruin the temper with careless buffing. Start with a coarser pre-polish ( grey, brown, or green) and then when all is evenly buffed, clean the blade off and go to the other finish buff. Use only fine green, pink, or white on this buff. The position of any edge, be it cutting edge, spine, or other projection, can catch the buff and rip the blade from your hand. Consider this when gripping the knife. Buff any edge with the edge down. Quit as you approach the other edge, and turn the blade around. Buffing longways, from ricasso to tip, works, but requires some practice.
If buffing wood it is best to use buffs that are only used on wood, as the metal oxides will stain the wood. Sand the wood to as fine as you are willing to go before buffing. Buff lightly and quickly, first with no-scratch pink or matchless white, and then with white or a plain buff ( some give the buff a charge of carnuba or other hard wood polish).
This is general and practical advise to everyone, but especially newbies. If you chose to use some less safe method,or have been doing it different for years, and it works well for you,..... fine ( I pray for people like you to be safe). But, please don't post such procedures for novices to read and assume that is how the pros do it.
I buff several hours a day, and have for over thirty years. I have a mishaps from time to time.....almost always because I wasn't doing the procedures I just posted.
Stacy
looks like the mickey mouse way to buff and he's gonna hurt himself any day now. Youtube should remove videos that give newbies too many bright ideas.
