So are you talking about how acute an edge is or how refined, both?No, there is no such thing as too sharp. A sharper knife will stay sharp longer than a duller knife.
Well I can't speak for someone else, but it has been put forward many times that if you have a good steel with good heat treat and good edge retention, if you set the bevel at an acute angle such as 15 degrees per side, then when the apex of the edge inevitably dulls, the edge will still be so thin that it effectively remains sharp anyway. The steel and the heat treat are important because in order for this to work well, your steel cannot be too soft or too brittle.So are you talking about how acute an edge is or how refined, both?
That's true, but if I go to acute with the angle on my kitchen knives they get sticky on the board. I also had a video that I can't find at the moment of a Japanese fishmonger that was very specific about his knife sharpening because if he went to refined he lost the feel.Well I can't speak for someone else, but it has been put forward many times that if you have a good steel with good heat treat and good edge retention, if you set the bevel at an acute angle such as 15 degrees per side, then when the apex of the edge inevitably dulls, the edge will still be so thin that it effectively remains sharp anyway. The steel and the heat treat are important because in order for this to work well, your steel cannot be too soft or too brittle.
I was talking about the width of the apex, but it's really both. A finer apex will cut longer and a lower edge angle will cut longer, assuming that the steel can support the chosen angle.So are you talking about how acute an edge is or how refined, both?
I think what people are reporting is the edge rolling. The edge might still be sharp, but that edge is nnow turned sidways.No, there is no such thing as too sharp. A sharper knife will stay sharp longer than a duller knife.
Or the edge is so thin and fragile , the edge breaks away ...I think what people are reporting is the edge rolling. The edge might still be sharp, but that edge is nnow turned sidways.
Scandi’s a bit of a special case. What was the edge angle? Maybe 8 dps? Probably a soft steel?Or the edge is so thin and fragile , the edge breaks away ...
How do I know - Cos I been there .. Sharpened a Scandi till it would cut layers of skin off .
But the edge ( Apex ) was weak , very weak . Can a knife be too sharp ?
Again depends on what your using it for .. But the answer is , Hell Yes !
I can understand two things :
A) Folks have never been there
B) Or their full of it ................ ( Something )
There is good D2 and Bad D2 ...I would say that D2 is not a steel that I would choose for a Scandi grind. It's not tough enough to support such an acute sharpening angle.
Only way to keep the knife sharp longer is to sharpen knife with more coarse sharpening medium . Period !Well I can't speak for someone else, but it has been put forward many times that if you have a good steel with good heat treat and good edge retention, if you set the bevel at an acute angle such as 15 degrees per side, then when the apex of the edge inevitably dulls, the edge will still be so thin that it effectively remains sharp anyway. The steel and the heat treat are important because in order for this to work well, your steel cannot be too soft or too brittle.
Even with dull tooth this saw will still cut wood .Try to cut wood with spine of saw![]()
Too sharp is a reality if the edge you created doesn't hold up to the purpose for which it was intended. An axe is a good example. You can get an axe with a convex edge really sharp - sharp enough to shave with. But it still isn't going to be as sharp as the edge on my straight razor that I also shave with because if it was, the first time I struck a log the edge would be rendered useless. In fact, you can even have a straight razor too sharp. I have on one occasion sharpened a straight razor so sharp using fine diamond paste that it would tend to cut your face just from the pressure of the razor held against it. That is too sharp to shave with, unless fine facial cuts and blood don't bother you. But for the norm of things, I would agree with you. Give me sharp every time over less sharp.No, there is no such thing as too sharp. A sharper knife will stay sharp longer than a duller knife.
