- Jun 22, 2016
Hi there! Thanks for taking time to read my post! I am a new knife maker and I am trying to mark my blades with my logo. I have not successfully put a clean, good looking mark on my blades yet and its super frustrating!
I am using a new logo from TUS Tech with electrolyte solution for high carbon steel from usaknifemaker.com. My etcher/marker can be used at 24V or 12V AC/DC. I usually only mark using the AC though at 24V. When I prepare to etch I try to clean the blade with alcohol and then I take the logo using blue painters tape (extra wide) and make sure it seals around the logo. Then I will hook up my etcher/marker to the blade. My marker probe is stainless steel with felt around the end. I take metal probe and hit it on the belt grinder for a few seconds to take off all of the black gunk that was left on there from the last etch. I also use a fresh pad each time.
My first issue is that I am getting ghosting around the stencil and I believe that might be caused by be running it at 24V and also too wet of a pad. I only get ghosting when I am running it at DC to etch. Not AC.
My main issue is that when I go to just mark (AC) by blade it seems that the black oxide is not sticking to my blade. I will do 30 quick passes over the stencil which is plenty to mark it well and it will show up on the blade until I rub it with a cloth and then most of it will just come right off. I am wondering if its because I didn't clean the blade well enough; there could be some leftover WD40 on it. I also clean the metal end of the probe off before I start etching and I use a fresh felt pad each time. Could this be happening because I don't have any metal built up in the pad or on the metal probe surface to deposit on the blade? I was also wondering if its because my probe is stainless steel and the blade metal is 1095 high carbon?
I have used a test piece of metal before (not heat treated) and I was getting really awesome marks on it but when I went to the blade it looks like crap. I don't think I cleaned the blade well enough and I did use a really wet pad on the blade but I feel like there is more going on here than a too wet of pad. Has anyone else seen most of their black marking basically rub off? I will try to post some pics!
Thank you for taking the time to read my issue! Any help would be greatly appreciated!
