- Nov 29, 2011
So some help here. I always hand finish the knifes I work on and have been using the various 3m wet and dry from the auto parts stores but that is freakin expensive. So I ordered a bunch of the Rhinowet red going off several guys here say its pretty good.
So its good at taking the metal off it seems. Loads up a little easier then the stuff I was using. My main issue is I cant seem to get a even sand with it. Either it starts out putting down some uneven looking sand lines or the little hooks showup really bad.
My process is similar to the tutorials here on the forum. Various sanding blocks, I use the spray remoil, clean work area all that stuff. I wanted to do just a satin 600 or 800 grit finish on a couple of blades but cant get that even look to it.
Any suggestions for working with this stuff or do I just need to keep working at it and try to get use to it.
Thanks.
Thanks.
