Square_peg
- Feb 1, 2012
Anytime you find axes form US or Europe is a good day. I like the shape of that West German hatchet.
Sure do like that drawshave. I have never seen one quite like that, it might have had a special purpose? Then again, it might just be the makers own idea of what a drawshave should look like.
I'm with you. It is hammered out of one piece of metal, and the backside is flat like normal. I also have not seen one of that design before. I do have my favorite already, so it will be available.
That surprises me. It sure looks like somebody forge welded a piece of rod to a piece of high carbon flat stock. I just can't see any blacksmith forging that out of one piece of steel and leaving that big bead on the back of the knife. Huge amount of detail work to do that for no apparent gain. And he took the easy way out on the handles, just poking straight thru and peening over the end. I don't think any smith would go out of his way to leave that high bead on the back and then go so quick & dirty on the handles.
The easier solution is that it's a piece of rod and a piece of flat stock. I'd lay odds.
The Collins is awesome - NOS for sure.
I live in the wrong part of the country......![]()
Looks like Americanax Glassport, PA stamp on the small one.
FWIW:sure does, thanks! Pretty cool since i grew up about 15 minutes from there.
Here is an example of an AMERICANAX with the TT stamp (not mine):
I cannot identify the age of your axe. I'm just suggesting that if your axe is clean enough that you could see a TT mark and don't, you probably have an axe older than TT.
Bob
. . . I have never seen one quite like that. . .
. . . I also have not seen one of that design before. . .
Me four. . . I've never seen anything like that. . .
Don't know what's going on here:. . . it might have had a special purpose? Then again, it might just be the makers own idea of what a drawshave should look like.
Dear lord. You find some good stuff, JB! That mint Collins with the label is awesome. I wonder what it's approximate age is?
What make are the double bit and the top axe?
