It's built like a workhorse and i will regret this but....
Feedback: +61 / =0 / -0
Just have to let this go:
A discontinued Spyderco Manix C95 in plain edge- The fantastic jimping and solid lockback mechanism are one of the best i've seen in the Spyderco range.
Length overall 8.812" (224 mm)
Length closed 5.063" (129 mm)
Blade length 3.75" (95 mm)
Blade steel CPM S30V
Blade thickness 0.156" (4 mm)
Cutting edge 3.25" (83 mm)
Weight 6.1 oz (174 g)
Handle material G-10
Condition 9/10
From Spyderco:
Start with an exceedingly strong lock, manufacture using precise tolerance measurements, and add a blade honed from the superior blade steel. Welcome the Manix.
The backlock is substantial, positioned mid-spine for smooth opening and closing of the blade. By skeletonizing the dual steel liners (which are nested into the G-10 handle) rigidity and strength are increased without adding unnecessary thickness or weight.
Outstanding ergos result from a fore-finder choil allowing you to choke up on the blade for better manipulation over the cutting edge.
Smooth open and closing action is due to the relationship between the blade's weight, the lock's shape and the spring's shape.
All a result of implementing precise, close manufacturing tolerances.
Made from premium S30V steel, the blade is double flat-ground with aggressive thumb serrations notched above the 14mm Spyderco Round Hole. This keeps the thumb gripped on the blade spine enhancing cutting performance.
Available in a Plain Edge or Combination Edge.
Carries ambidextrously with a steel clip that positions the knife for tip up/down carry.
Made in Golden, Colorado U.S.A. Earth
Other than the worn look on the clip pretty much everything is great in condition;Buttery smooth oiled pivot, centered blade and solid lockup.
It's a safe queen and i believe someone out there is looking for one.
Doesn't come with a box but i can provide one from Spyderco.
I'm glad to have this shipped worldwide at 230USD with tracking number and insurance.
First to PM “I will take it” gets the knife.
