- Dec 6, 2010
Looks like you'll need a puller.
Good thing you got that puller. Sometimes it's the only thing that will work.
I have a grinder motor in my shop that has the front busted right out of the motor casting, from me trying to remove an aluminum hub without a puller. Glad that didn't happen to you.
Another thought, the original grinder was 1 speed right? Could it have come with two or more different rims in order to change belt speed?
I suspect 300F and a nylon mallet will dislodge the wheel.
I did have to resort to a puller, the beam and sliding bar jaw type to get over the Hub.
The Drive Wheel came off with a "chirp" of movement every turn of the screw or so with a crescent wrench.
Never seen an aluminum wheel fit that tight on a steel shaft.
I ran a 5/8 hand reamer thru the hub, polished the key faces and motor shaft with some 320 grit emory cloth.
It slides on the motor shaft freely now, less key.
