Jade Ghost G10
I just got some of this stuff off usaknifemaker.
What is the best looking finish for it?
Does anyone have any pictures or links to finished knives with it?
I appreciate any help. Thanks all.
Best when used with a thin white liner and sanded to 1500 then a light buff.
Stan
The stuff has been used just about everywhere
Just doing a goggle images search with "Jade Ghost G10 knife" will give you hundreds of photos
I like it fine sanded to a clean 600 grit and buffed with pink or white rouge. IME that's high enough to avoid dark scratches in the finish. Stan's right that it's better over liners- it's quite translucent and may show fastener shadows and any dark spots on the tang. I like a white or green liner with it.
Be careful when sanding it next to metal, such as the tang edge or a bolster/guard- it will pick up smudging from the metal. Best bet is to keep you paper clean and new, and sand high enough that grime won't smudge it anymore. Cleaning with a rag and some WD40 or PB blaster will remove smudges during finishing and after buffing. Smudges that stay after buffing and oiling need to be sanded higher or more thoroughly.
It's much like working with any light colored synthetic handle material in these respects.
Thanks everyone.
In regards to the translucency. On my knives in the past, I've drilled little holes in the liners and handle material for the epoxy to grab onto. What's the best route here, if you might be able to see through to the liner?
Make the holes look cool! Seriously, you can see them some through the Jade G10. It is some good looking material in my opinion.
