Jake Hoback Custom Axe at the KnifeCenter
KnifeCenter
Dealer / Materials Provider
Feedback: +3 / =0 / -0
JHKPROOF: PROOF of Life Axe
Jake Hoback Custom Knives
"Proof of Life" is something a hostage negotiator asks for before negotiating the return of a kidnap victim. Jake chose the name for two reasons: First, this is a collaboration with PROOF Research! And second, this axe absolutely has a lot of life in it! He took a unique approach to this collaboration. PROOF Research supplied Jake with mountains of information on carbon fiber, and the carbon fiber itself – for the handles – and he came up with the overall design and machined the axes. If you’re unfamiliar with PROOF Research, their Barrels and Rifles are the utmost in lightweight, strength, and accuracy. They sell exceptional products!
The Handle
Uni-directional carbon fiber, UD tape laminate, a very expensive IM fiber, and a toughened 350F aerospace resin system. It is fully 3D machined to give not only texture but structure to the handles. The direction of the fiber runs parallel with the handle of the axe to aid in structural integrity and reduce harmonics transferred to the hand.
The Axe
Take a 1/3rd tomahawk, 1/3rd crash axe, and a 1/3rd ultralight and mix them together with a pinch of hate and a few drops of blood and you get this monstrosity that is only 1 lb 2.6 ounces! It will eat anything you can throw at it since it’s over 0.29" of S7 tool steel. Jake didn’t just toss a cool look onto his computer and machine it out. He designed every detail to a “T.”
The Head
Scalloped bevels aid in forced cutting direction, which means no more glancing blows that slide off-target and hamstring you (because everyone would laugh at you) so you can comfortably take a very manly swing! The ridges (scallops) are meant to drive the blade deeper into the object. While we talk about the bevels, take a closer look at the top front bevel compared to the bottom. The top one is at a steeper angle so that it has more meat behind the edge. The bottom line is that the top edge is meant for abuse and the bottom edge for the finer cutting. Wait...hold the phone, you mean someone actually took the time to look at how the tool cuts and improve the geometry to create a tool that has better performance, that’s balderdash!!! Why not just make it all the same and hawk (pun intended) it to the masses. Hmm, might make me more money in the long run. It does take more time, but that’s what Jake does!
The Handle
Again, no compromise. Angles are set to aid in quick positive cutting action and reduce shock to the hand/arm. No hot spots for your hands to get blisters.
Internal Lightening Pockets
Just like all Jake Hoback folders and fixed blades, a lot of thought goes into the lightening of anything. You can’t just remove material because chances are you will compromise the structural integrity of the item. So we’ll tell you that Jake left all the good stuff and removed all the stuff that didn’t matter. All corners have at least a 1/8th radius, and he left internal webbing inside the handle to keep flexure to a minimum. So at the end of the day, you have an axe that weighs 18.6 ounces and has all the strength of an axe that weighs twice as much.
Balance
The balance is right at the topmost handle bolt. Jake designed this tool to be light and fast. It’s not a camp hawk or a bearded axe for hewing logs, it’s meant for professionals who need a tool that can actually be carried and used, instead of left in a gear locker because it’s too heavy and unwieldy to carry. Balance is very important for swinging things, you don’t want all the weight to be at the head because it would not allow for a quick withdrawal – or if it’s too heavy forward it could allow too much over-swing, which is dangerous. People who use tools like this need to be fast and controlled. Good balance and lightweight equal control.
Handle Bolts
Jake decided that he really hated having to use two tools to undo a handle, so he designed the handle bolts to use the pivots from his old school custom folders. The head is cammed so it cannot rotate once properly locked into place on the handle. Then all it takes is one flat head screwdriver to unscrew it and remove the handles.
