Collaborative Knife by Jay Fisher and James Beauchamp
Size: Length overall: 11.875" (30.2 cm), Blade Length: 6.5" (16.5 cm), Thickness: .202" (5.1 mm)
Weight: Knife: 12.6 oz. (357 grams) Sheath: 9.2 oz. (261 grams)
Blade: 440C High Chromium Martensitic Stainless Tool Steel, Hardened and Tempered to Rockwell C59
Bolsters: Fittings: 304 Austenitic Stainless Steel
Handle: G10 Fiberglass Epoxy Laminate
Sheath: Locking Kydex, Aluminum, Stainless Steel, Nickel Plated Steel
Knife: Another fine collaborative knife by James Beauchamp and Jay Fisher, the Bulldog is a tough tactical grade knife. The deeply hollow ground blade is low care 440C high chromium martensitic tool steel for great wear characteristics and extreme corrosion resistance.
The blade has a very aggressive point and a half-length top swage to reduce point thickness without sacrificing spine strength. The thick blade has a full tang: one solid piece of steel from point to finger ring. The bolsters are tough 304 high chromium, high nickel austenitic stainless steel for the greatest longevity and zero care. 304 is the same steel used in 18-8 stainless steel bolts, nuts, and industrial fasteners. The bolsters bed a pair of pinned and dovetailed G10 fiberglass epoxy laminate manmade handle scales. This very tough, hard, and durable material is industrially manufactured for high compression resistance, toughness, and chemical resistance. A unique feature of the Bulldog knife is the rear finger ring. The ring aids in extracting the knife from the sheath to be held in reverse grip style. The 1" diameter ring is contoured and smoothed for easy and comfortable use. This is a very durable, aggressive, and field-proven knife.
Sheath: The sheath for this knife is one of James' and Jay's positively locking military tactical combat models, made of double thickness Kydex, 5052H32 corrosion resistant high strength aluminum, 304, 302, and 316 stainless steel locking mechanism and components, bound with nickel plated steel Chicago screws and 18-8 stainless machine screws. The belt loops are reversible for a variety of wear positions.
See the High Quality Photos at: http://www.jayfisher.com/JBF_Col_Bulldog_G10.htm
Price: $1,500
