Beautiful knife, amazing action. super light. The loudest opening sound i've heard from such a small blade.
Has some pocket wear (snail trails) most notably on the clip. retail was 590$
Asking 450$
paypal g/s priority included (no notes PLEASE)
Specs from BG:
Blade length: 2.80 in.
Cutting edge length: 2.75 in.
Total length: 6.70 in.
Blade height (at heel): 0.90 in.
Blade thickness (near bolster): 0.13 in.
Blade thickness (at midpoint): 0.12 in.
Blade thickness (near tip): 0.04 in.
Item weight: 2.40 oz.
Shipment weight: 3.6 oz.
Blade: Satin finished Bohler N690 stainless steel
Handle: Black titanium with silver strike carbon fiber inlay
Sheath: Zipper pouch
Style: IKBS front flipper with frame lock
Description: JD van Deventer creates unique knives of the highest degree of craftsmanship and performance. He took up knife making in 2005 and became a member of the Knifemaker’s Guild of Southern Africa by 2007. He works in a one man shop and even builds most of his machines himself! He is clearly a maker to keep an eye on!
This bolster lock folder is an extremely practical, yet elegant EDC -- designed for daily carry and daily use. Weighing in at just under 2-1/2 oz, it is easy to keep close at hand and not even notice it is in your pocket. This special EDC bolster lock includes some important upgrades such as the addition of IKBS ball bearings, a bolster lock, and a 3D machined tip-up titanium pocket clip.
The blade is perfectly centered with silky smooth action -- easily opened with one hand using the discreet and ambidextrous flipper toggle. It uses the IKBS (Ikoma Korth Bearing System) pivot system. This mechanism, which was originally designed to fit balisong knives, uses ball bearings to create exceptional action with no blade play.
The blade is hand ground from N690 stainless steel, created by Bohler in Austria. It takes an incredibly sharp edge and holds on to it. Increased toughness gives it better resistance to edge chipping. The blade is hollow ground for an easy to maintain edge. By differentially polishing the blade, JD emphasizes his clean grinds.
The frame is formed from blackened titanium with silver strike carbon fiber inlays on both sides. The ergonomic handle and jimping along the spine provide a solid, secure grip. The blackened 3D machined titanium pocket clip is mounted for right-side, tip-up carry.
Asking 450$
Specs from BG:
