JD WARE Slim Slip-Joint: Gold Leafed Bull Horn (SOLD)
Feedback: +17 / =0 / -0
One last knife for now…. this is a beautiful, Slim, Slip-Joint Folding Knife with Gold Leafed, Bull Horn handles and fully file worked blade and spring of 3/32” CPM 154 steel.
Closed length of the knife is 4-1/8”” including the lanyard loop. Blade is 2-7/8” flat ground with a belt satin-finish. Nickel Silver liners (relieved). Nickel Silver pins and file-worked bolsters. The Silver Escutcheon is made from an 18th century Spanish Half Reale coin. The spine of blade with thumb grooves; blade and spring with geometric file work. This is my first knife with a file worked spring - thanks to Stan Buzek for his advice on doing this work.
The handles are Bull Horn backed with 23 carat Gold Leaf. The Gold Leaf between the horn and the liners really gives depth and brilliance to the translucent areas of the horn. I collect the horns from La Corrida (the Bullfight) here in Merida and in the neighbouring pueblo of Motul.
This horn came from a bull fought by the world famous Spanish Rejoneador, Pablo Hermoso de Mendoza (a Rejoneador fights from horseback). Below is a photo of Hermoso de Mendoza in action and a photo of me cutting a horn. I boil the horns to clean them and loosen the outer horn from the bone. The horns are boiled again to soften them, then pressed flat, dried and cut.
This knife is “under-bladed” meaning that in the open position, the spine of the blade is just slightly lower than the top surface of the backspring**. This is an intentional design element that is often seen in old Sheffield knives. Without this feature, over time, as a knife is used, the blade will want to “climb up” over the back spring. The photo of the spine of the open knife shows the under blading clearly. The backspring itself is flush with the liners in the open and closed positions. There is no half-stop. The knife opens with a medium-easy pull. Supplied shaving sharp.
Included is a handmade leather pocket sheath. $375 Sold (including shipping via FedEx economical insured to US, Canada or Mexico. $15 extra to most of EU. By quote elsewhere)
If you'd like, I can engrave up to three initials in the Coin Silver Escutcheon for an additional $25
I am a full time knifemaker working in Merida, Yucatan Mexico. I use almost exclusively local handle materials that I gather and mill or process myself. Dense tropical hardwoods as well as wild and ranched deer, cow, bull and water buffalo horns.
The silver escutcheons are made from old Mexican silver coins and are pinned through the liners. You can still see some of the surface irregularities of the coins. All of the pins are nickel silver and are hammered over and left slightly proud of the handle. The decorative file work and carving are precise and carefully done, but you can also see that it was done by hand – I don’t sand or polish the file-cuts.
Please checkout my website for more information about my work JDWARE KNIVES
If you want to purchase this knife or have questions or comments, post here, pm me, or contact me through my website. I accept PayPal and credit cards.
Thanks for looking
J
**There have been a few discussions on the forum on under-bladed knives, including HERE
Beautiful Jeff. Great catch on that one Dennis... Wish I would have seen that first.
Thank you, this knife is sold.
I really like working with this Bull Horn. The horns are all a little different from each other, and each horn varies a great deal from end to end - opaque black and white at the tip and becoming golden and translucent at the base.
Doing file work on the spring has required me to adjust my working methods a little. I used to do most of the final profiling of the spring/handle assembly post heat treat. Now, it's almost all done pre heat treat. I've also started drawing the knives actual size... gives me another way to look at them:
Saludos
J
Here's a photo of the coin I used for the escutcheon. Couldn't make out the date or mint, but enough of the design was there to see it was a Spanish Colonial Half-Reale. I didn't do too much to it: just smoothed out the surface, polished the edges and curved it to fit the handle.
Saludos
J
Jeff,
Thanks for sharing the additional information on the knife. Really neat to see.
J,
Your knives are always ABSOLUTELY BEAUTIFUL, this one is ABSOLUTELY SPECTACULAR.
GREAT MATERIALS, GREAT DESIGN, GREAT CRAFTSMANSHIP !!!
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Dennis,
Your doing O.K. ;)
Doing better than that Tim ... check your PMs in a few minutes! And yes, this one is gorgeous. Glad I saw it quickly enough.
Folks ... I have to tell you, this one is absolutely beautiful. And even more amazing is that it made it from the Yucatan to my door in Pennsylvania in 24 hours!!! Here's one pic I took in which I was able to catch the beauty of the gold leaf under the horn:
