I have a mint condition only used for a few days (no more than a half hour total), jetbeam Jet III M with the XML Led.
Asking GONE shipped using paypal personal/gift option or add 4% for fees.
Comes with box, papers, extra o rings, lanyard, and extra tailcap rubber piece.
Pm or email me if interested..
Info about the light below.
We are pleased to announce the latest revision of the best selling Jet-III M. Improvements include: Updated LED (Cree Cree XM-L LED (T6)450+ Lumens, redesigned tail cap which can be operated with gloved hands, redesigned aluminum reflector for Cree XM-L, improved shock resistant spring on positive terminal, and improved circuit design to increase efficiency and overall output.
The Jet-III-M (Military/LE Series)
Specially designed for Military and Law Enforcement.
Simple and convenient UI, two modes can be switched easily
User-defined mode provides various brightness levels and different functions.
Infinitely variable brightness system, no more traditional restrictions of preset brightness levels.
Stainless steel retaining bezel on head, prevents damage from impacts.
Redesigned tail cap allows operation with gloved hands
The two-way removable pocket clip also doubles as an anti-roll feature
The light output reaches (Cree XM-L Cool Tint) 450+ lumens, and has an effective range of 200+ yards
The latest generation circuit is designed to maximize efficiency and a broader voltage range, which is compatible with CR123 batteries and rechargeable lithium batteries (including 18650 & 16340 lithium batteries)
Extended run time, lasts continuously for more than 200 hours.
Waterproof accords IPX 8 standard
Resistance to impact by dropping according to US MIL-STD-810F standard.
Remote switch and Weapon mount available
Specs:
LED: CREE XM-L (T6)
Reflector: Aluminum reflector
Lens: Coated mineral glass
Material: Aero grade aluminum alloy
Finish: HA III Military grade hard anodized
Battery: Two CR123 or RCR123 batteries or one 18650 rechargeable li-ion battery
Dimensions: Head diameter 33mm, tube diameter 25.4mm, total length 138mm
Weight: 118g (without battery)
Waterproof: IPX-8 standard waterproof
Accessories: Lanyard, spare rubber tailcap switch cover, spare O-ring
Output & Runtime
Highest mode 450 ANSI Lumens 1 hours 30mins
Lowest mode 0.3 ANSI Lumens 200 hours
Maximum peak beam intensity 6380cd
Maximum beam distance 200m
1.5 m (Impact Resistant)
IPX-8, 2m (Waterproof and Submersible)
Specs:
LED: CREE XM-L (T6)
Output & Runtime
