Hi, Gary...
Re the dimensions of the Jungle Honey: Overall length runs somewhere around thirty one inches, length divided about equally between blade and handle. The reason for this odd construction is pretty simple. With a sword, either short or long, little cutting is done with the area of the blade near the handle, so I thought it might make sense to increase handle length so one could 'choke up' on the handle when using the Honey one handed. Gripping at the top of the handle puts the hand right at the balance point of the piece and allows it to be maneuvered about as easily as, say, a ten inch camp knife. Easy to swing, but with much more momentum. Using two hands, the Honey becomes a sword, and not such a short one at that. The blade is wide... 2 1/2 to 3 inches at the widest point... and fairly thin at maybe .2 inches. Cutting power is good. The Honey will sever a two by four in two easy strokes. It's also good for thrusting. The best I've managed to do on half inch plywood using two hands on the handle for a full power thrust, is to get 4 1/2 inches of blade sticking out the back of the plywood. The picture you have posted is of a Jungle Honey I made for a young Marine friend of mine who was headed out several years ago to a trouble spot in Africa. He wanted something which never jammed, nor ran out of ammo. Apparently he caught some flack for carrying a non-issue weapon (he carried it in an over the shoulder sheath) until everyone in his platoon began to borrow it for every chore imaginable. Steel is 1095, by the way.
I'd also like to say thanks to you, Gary, and to the rest of you knife folks for the kind words about my work.
May your blades never dull.
Oley
