Journeyman Smith Performance Test Knife
Good luck on your test! I'm probably beating a dead horse with this, but make sure you read the JS testing rules, and then read them again and again. I say this because I have had a number of people show up at my shop to test, only to be turned away because their test blade did not meet the specs outline in the rules.
Another portion of the rules that have failed a couple of folks who have come to me to test......
2. WOOD CHOPPING: THE PURPOSE OF THIS TEST IS TO DEMONSTRATE EDGE TOUGHNESS.
The chopping test is to be conducted with 2x4 construction grade wood stud. The 2x4 may be either hand held or clamped into a vise or other safe devise. A chopping motion (no whittling) is to be used. The 2x4 must be chopped completely through a minimum of two (2) times. The applicant may choose the area of the 2x4 through which to chop. Following the chopping test, the Master Smith will inspect the edge to determine if there is any noticeable damage to the blade. Any nicks, chips, flat spots, rolled edges, or other deformations of the blade will result in failing the test.
I'm not trying to spook you, just want to ensure your aware.
Good luck Kyle but I dont think you need it. By the looks of that cool heat treatment you will pass it easy. Remember to not jerk on the bending part. :)
Kyle, looks like you got it together. I don't believe you'll have any trouble but Ed's advise above is solid.
Thanks for the kind words everyone! :thumbup: :)
I hope it passes, especially now that everyone knows I'm taking the test.
Thanks,
Kyle
Sweet Kyle!!! :cool:
More proof I feel it is very safe to say you will go as far in this craft as you choose.
Not very often you see somebody off to that kind of start so quick.... LET ALONE at your age.
Keep us posted!!!! :D :thumbup:
It's always amazed me how gracious customs makers (especially ABS forgers) are at sharing their knowledge with new makers. I have never seen anything like it in other collectible communities. It's like you are all pulling for the team when makers test.
