I was referring to your "snapped" samples in the pic from post #50, immediately prior to my reply in post #51. If you have failure samples, they were subjected to shear forces to impart the failure.
I agree - sorry it's maybe a little obscure. I showed the picture of the shiny spot on the edge first and then snapped samples to see if something similar appeared in them. It does. It may not be the same thing in both.
the difference in the edge quality is extremely unusual, though - I've never seen it before having taken hundreds of pictures. It makes me think the composition of the steel at that spot doesn't match its surroundings.
It's not terminal in plane irons, you can see that the wear looks almost the same, and the carbides still show/look similar, but the spots do impart a different finish on wood. I use the uniformity of the result on wood as an indicator of edge quality and uniformity.
Here is an example of an unfinished piece of wood that's been planed cleanly - it's reflective when viewed along its length which makes it a quick indicator of defects in an edge - even something a thousandth of an inch stands out boldly, as do changes in surface quality. This may not amount to much talking about knives, but for wood plane irons, if you can pick up a piece of wood and see uniformity all the way through the dulling cycle, you know you may not really need to look at anything through the scope.
A poor quality iron will show lines easily, as will one that's undertough (this isn't uncommon on commercial irons), or one that's too tough and not as hard as it should be.
