- Mar 8, 2011
+1.if you have a good round file i would try to get that top of the eye cleaned up so you have good contact through the whole eye to the handle. im not sure but i would imagine if you have a bits eye that has play with the handle your asking for possible breakage through any heavy usage.
Make sure the eye tapers in the correct direction & file if necessary.
Mark the handle orientation & fit it tight then remove it, take a little (sandpaper or a fine shaving with a rasp or knife) off the handle where there are "witness marks", meaning marks the head left on the haft where it touched the inside of the eye, use soot, a permanent marker or pencil graphite on the inside of the eye if you have trouble seeing where it contacts.
Repeat until it fits snuggly, this might take many fittings but is worth the effort for a durable tool.
