- Aug 10, 2010
I'm new to this also, what kind of speed do you sharpen at? I assume just make a pass or two then cool the blade?
do you got a link to th knfie center one? There might be nothing at all different.
I use the paper wheels for sharpening too. If I was rebuilding my set up, here are couple of things I would consider. I would buy a variable speed grinder. These were not as common 15 years ago when I got mine, but I may change it now anyway. I used the smallest profile motor. This gives more room to work around each wheel. I used 1700 instead of 3450 rpm, if not variable speed.
Also, a few years ago, I started using the wheels while running the grinder turned around backwards. This way I sharpen on the top of the wheels and the motor is turning away from me. Before I was holding the knife with the cutting edge down and using the part of the wheel right in front of me. I changed to the backward method because it is easier to see when a burr forms. I just have to be careful when reaching for the power switch on the other side of the grinder.
Bob
I opened up my grinder and turned the motor around.Now the switch is in the right place.
