I think that knives made by machinists have a certain look to them. Not better or worse, just a little different. Surface ground flats, heh heh...
Crit:
I wonder about the ergonomics of the handle, both in profile and in cross section. And I'd like the appearance better if the guard were a bit narrower.
Observation:
D2 is not as easy to do well as I thought it was (before I started using it for knives). If it didn't fully harden, something was off about the HT that you need to figure out. It may not matter on this one, but it is a wonderful steel, so if you're wanting to improve your results on the next one, I suggest you first make some test blanks and evaluate for yourself how the HT effects edge stability, edge retention in abrasion, and corrosion resistance. I found that the steel needs a good long soak time (30 - 40 min) cryo as part of quench (otherwise, it is designed to retain austenite, and it will) and you can't just re-heat treat it if you don't like the first stab at it because grain size can go from 10 to 3!
Recommendation:
I'd suggest making another one that isn't so pretty that you can use and start to judge for yourself how your grind geometry and edge geometry affect the cutting performance and start to develop a wish list for your next one. You learn by using them.
I think that is a great first knife.
