Esav Benyamin
MidniteSuperMod
- Apr 6, 2000
The best way to protect a carbon steel blade from rust is to develop a patina. Simply dip the blade in a mild acid like vinegar and keep it there until you are satisfied with the shade to which it has darkened. Then rinse it in cold water, dry it, oil it, and just remember to clean it as soon as possible after use.
Drip oil around the pivot and flex it a bit. The oil will work its way in. Use a bit of cloth or a Q-Tip to oil the liners, although the liners are probably stainless, as most structural metal is. There should be no space between the liners and the scales, but if there is, drip a bit of oil in there, too.
I like food grade mineral oil, since it is entirely harmless if ingested, and works well as a lubricant and a protectant. But don't overdo it and end up catching lint and dirt in the oil.
I believe mineral oil is the base of camellia oil, with camellia essence added.
