- Sep 19, 2001
I use mine dry and just wash it off when done. You can use it wet, do equal strokes per side or work one side completely, edge leading or trailing, push parallel in sections of the edge, drag the entire edge diagonally across, use circular motions, start at the tip or the ricasso, hold the blade steady and file with the sharpener, etc etc.
The only thing you need to be consistent with is the angle, that will save you time. Whatever motion you use, do it until you feel a burr. Then make very light passes until the burr goes away. Then move to the next finer grit and repeat. After some practice, you will stop at smaller and smaller burrs, and have better control over the pressure you apply. Just practice on getting your angle first, DMTs make it easier without having to worry about loading up a lot or dishing out while sharpening.
