It was harder to open mine with the flipper and I couldn't use the thumb studs. After I deassisted it, I can flick it open with the thumb studs easily and the flipper is perfect. I can even middle finger flick it open with the studsHi All, new to the forums here
Got my 0566 last week and damn that thing is hard to open! It was tearing apart my index finger from flipping into the jimping. I de-assisted it and played with the handle and pivot screws to get the centering down for about 5 minutes and DANG, it's silky smooth now. I can also actually use the blade stops to flick it open with ease. I was seriously thinking about returning this knife ( I have never returned a knife before) and figured I would give this a shot and it changed the knife! Does anyone actually prefer the assisted opening? Maybe mine was just a fluke about how hard it was to open but the spring plus the detent made it impossible to open with the blade stops and painful to open with the flipper. Plus, it didn't even open that fast with the spring anyway.
Is it easy to Re Assist the 566 if needed? Not that I plan on it. I don't have the spring.
Mine is also de-assisted and the washers were replaced with hinderer washers. After some heavy use at work it's now broken in and CRAZY smooth! The blade now closes under the weight of the blade. The pivot screw needs a tiny bit of tightening occasionally to minimize blade play, but I use it pretty heavily on a daily basis. The detent is good. I've never had a problem with it opening in my pocket despite the fact that I carry it "tip up" style and I do quite a bit of running and jumping at work. Now I just need to figure out how to get this elmax steel razor sharp with my fine grit ceramic rods![]()
Smaller one on the G-10 side. It's sized that way to allow movement of the torsion bar.
Buuuuut, since you de-assisted it you should just replace the small washer with another larger one. I've heard this helps smooth the action out a tad.
thanks for the tip, GS!
