edited to add: Stan's talking about only removing from the green area, leave the red area alone.
Here's what I'm talking about. If the pivot pin was in place, and the rear pin was in place, the center pin wouldn't line up with the hole you have drilled in the frame. In my head, the amount that they don't line up is called the offset.
For instance, on yours, since it's hard to open, has a large offset and a thick spring cause you really had to force the spring to move when you put in whatever pin you put in last. A lot of the tutorials I've looked at give different amounts to offset that hole. Some people stick to that amount and vary the thickness of the spring. I'm just saying you can play with how far that hole is offset for a different feel.
Especially when I'm trying a different metal or a different temper on the spring I'll try different amounts of offset. I'll tweak the snap from there with removing metal from the spring if I have to.
A large offset with a thinner spring can have the same spring strength as a small offset with a thicker spring, but each will have a different amount of aggressiveness or snap in the action.
Here's one I'm finishing up now. It has a small offset, but because it has a thick spring it has a very aggressive, authoritative, dependable snap. I have some that have a large offset and thin spring and they have a very different feel that's a smoother, silkier and more refined. It depends on what you like.
Slipjoints are fun
[video=youtube_share;NCyXwgr90TM]http://youtu.be/NCyXwgr90TM[/video]
