munk said:The care for horn is to use lanolin. You can use handcream with this in it, or go to a pharmacy and get pure lanolin. You can also use hooflex, a vet supply store product which is used to treat the hooves of horsies. The horsies go, 'neeeeeeeiiggghhhh' when you put the hooflex on their hooves. The horn handle on your khuk should not make any sound at all. If it does, there are other forums that will help you with that.
munk
munk
Astrodada said:Thanks munk.................
I shall go matt............
munk said:Sure, put it on antler.
And if it's hooflex you are using, put some on the callous's on your feet. It helps to remove the uneccesary build up which in Winter cracks down to the pink meat and hurts like hell. And remember, when you apply hooflex to the hooves of a horsie, he goes: "neeeeeeeeiiiiiiigggghhhhhhh-yah!"
munk
jamesraykenney said:Forgot to ask before.... Do you put it on bone also???
But what exactly is the difference between horn and antler???
munk said:You can easily drive yourself insane trying to keep a mirror finish on a blade that is used in the field.
munk said:There's a blade I can trust.
