> Where'd you pick that up?
Here.
It is a truly fantastic gentleman knife. Not cheap, but it offers quality, if you can live with the constraints of a ceramic blade (which I think are pretty ok for a gentlemen knife).
It seems like a ceramic blade would be very sharp, so it would be fine to cut most things with (very little pressure would be needed), and it would hold that edge for a long time, no?
Hold an edge? absolutely yes.
Cut with little pressure? No less pressure than with a steel blade.
It's ceramic not steel so the hardness would be measured by some other system than Rockwell.
> Whats the long of the blade on those poket knifes? It says 40 and 50. Blade or OL?
These pocket knifes exist in 40mm and 50mm blades, and the ones with "simpler" (cheaper) ceramic have a different handle inlay. The blade of mine is 50mm. Thus it is pretty small.
Perhaps you have seen my thread "Guess what the two favorite knives in my core collection are?" - I relink the picture here so you can compare the size of the Kyocera to a number of other ones:
> How sharp can you get the kyocera?
It's not something you can sharpen yourself, it has to be sent back to kyocera for that. But that's acceptable since it holds its edge very, very well.
Not even diamond?
> will it split hair?
I haven't checked yet. It does dry shaving.
