- Jul 31, 2002
James-
Thanks for taking the time to share your thoughts. It's nice to get another perspective. These days about the only knives in that length range I use are kitchen knives; I've pretty much settled on using folders paired with a very large knife instead. So I was wondering if there was just something simple I'd forgotten.
I've really been paying attention to threads that discuss balance these days, and there are some things I'd like to add as well.
Having more mass in the blade or saying "blade heavy" is not really the same thing as discussing the balance point though, like you were talking about in post #14. I can agree that you'd lose some tip control if the blade is too heavy for the rest of the package, but the same thing can be said about blades that get too light. The word "balance" implies that too much is just as bad as too little. It usually seems to me that most guys will err on the light side. The guys on swordforum have often pointed out that if the blade is balanced too light, it's easy to overcorrect and get even less control. It reminds me of shotgunners who want to use really short, light barrels to make the gun "quicker".
Again, I can agree that a slow knife is a bad thing in a defensive type scenario, but at the same time, the balance point isn't what determines this. You could have two knives of the same length, weight, and balance point that handle totally differently.
I can see this arguement if you're keeping your wrist locked in a convulsive grip. In that case you're moving the blade/hand as a whole. I believe I can see your point about reverse grip as well, but I don't have a lot of experience in that area. But if we start talking about things that involve lots of wrist movement/snapping and blade rotation, then the above may not be true. In fact, the handle heavy knife may actually be slower.
It may or may not be well balanced, but it ain't because the balance point is 1/2" in front of the guard, either way. Speed and power don't have to be in opposition to each other. You can have them both at the same time with proper balance. (I used the word balance here to be far more encompassing- taking into consideration your physical strength and the amount of blade presence to accomplish whatever task) My big bowie maneuvers faster than a machete and out chops my 32 oz HI khukri.
All that said, I'm still interested in hearing your thoughts on the matter, especially the parts about reverse grip. I find myself wondering if its just the difference in the way your interacting with the knife, or if "wagging the dog" just isn't as effective in reverse grip....
James Green Dragon said:A 9" blade should be considerably blade heavy IMO. The longer reach & blade heavy balance make for a more effective chopper. And the added reach helps to compensate for the clumsy-ish feel for self defense applications - there is a fine line there... For example, you need some tip control if you are going to use the point in a SD application - go too blade heavy & you loose some of that...
James Green Dragon said:So I like a balance point just on the blade heavy side of neutral for the ~7" knives - especially for self defense applications: if you go too blade heavy it makes for slower recovery from your swings & makes the knife less suitable for reverse grip applications.
I still have a hard time calling 7 inch bladed knives "Bowie knives".James Green Dragon said:Bowie knives in the ~7" blade range can really vary allot:
For example, the old marine combat knife is slightly handle heavy.... This does translate to fast recovery in self defense though.
The Ontario SP6 balances ~1/2" in front of the handguard. This is a pretty decent compromise that makes for powerful cuts yet relatively fast recovery. It's pretty well balanced for a blade its size.
