KaBar Dozier 4062 Folding Hunter Review
Specifications: 3" satin stainless spearpoint blade. 4.25" black Zytel handle. Lockback. Reversible black pocket clip. Reversible thumb stud. $26 shipped.
The Review I wanted a smaller knife that I could use for every day carry, mostly utility. This knife fits. It came out of the box pretty sharp, but 30 seconds on a ceramic rod brought it to a razor edge. Since I got it last night, I sliced tissue boxes, paper, shaved hair, sparked some flint, and cut through two-liter bottles. It doesn't need resharpening.
The handle's texture and size feels comfortable; not too big and not too small. I can hold it in either a hammer grip or reverse grip with a little handle left to spare (I have big hands too). There is a hole in the rear of the handle, right behind the pocket clip, if you want to attach a lanyard.
The blade ends in a spear point, although this knife is also available with a drop point. The back of the blade near the handle has six grooves in it, which give plenty of friction so your finger doesn't slip on the blade when making deep cuts. The blade is also adjustable with a Torx-head bit. With this you can adjust how easy (or hard) it is to open your knife.
The lockback design is just like the one you've seen on every other knife. When locked open, there is no blade play. The blade won't collapse if pressure is applied to the blade. It passes the spine-whack test.
The pocket clip and thumb stub are both reversible using Torx-head bits. The clip is mounted for tip-up carry. A lot of people have commented about their dislike for the pocket clip... I won't be one of them. It holds the knife secure to whatever I put it on. Even when I mounted it upside-down (ie. tip-down with the clip's open end up) in my coat sleeve right above the wrist. The thumb stud is knurled so there is no slipping.
In closing, this knife is definitely worth the $26 I paid for it. I may be getting another one, this time with the drop point blade.
Dozier makes some very nice designs, and the Kbar folders look like a true value.
IF you have access to a micrometer, can you measure the thickness of the balde directly behind the edge, i.e. where the primary grind meets the edge grind?
Thanks,
KT
Thanks, and thank you for taking the time to write the review.
One other question, how does this knife compare to similiar knives you have used?
For example, compared to a Spyderco Delica or the like, what is the cutting performance, grip security, ease of opening, lock strength and stability, etc.
If you don't have time to answer these question, I understand, and thank you for your consideration.
Comparable knives that I've owned would be a Buck 110, Gerber EZ-Out, or a Spyderco Endura.
Cutting performance is better than the Buck, a little better than the Gerber, and a bit worse than the Spyderco. Although I think the edge holds up better than any of them.
Grip security... pretty good. There aren't any finger grooves, but there is a somewhat deep depression in the handle so it stays put. The somewhat aggressive pattern in the Zytel also helps more than you would think. Unless you hold the knife in a reverse grip and stab something really hard (something you shouldn't do with a 3" bladed folding hunting knife) you won't lose it. Even if you do, you still have a good .75" of rough handle to stop your finger from catching the blade.
Ease of opening, this is user adjustable. The thumb stub is reversible. The blade pivot pin is also adjustable so you can vary how much tension is needed to open the knife. Both use a Torx-head bit for adjustment. The thumb stud is positioned well, not too high and not too low.
Lock strength is great for a $20 folder. The knife passed my spine-whack test, both on my leg and again on hard wood. I tried to squeeze the handle in all kinds of positions to see if I could get the lock to fail, or to "accidentally" disengage the lock. Didn't work. The only way to close the knife is by pressing the lock into the handle and closing the blade. And that's how it should be. Oh, when you open the knife, you get a very audible "click" which I like :-)
Like I said, a great knife. I'm getting another one soon.
Thank you for sharing your impressions.
Sounds like a good knife for the price. I will pick one up soon.
