Home Despot sells Gardner Bender switches
The 20 amp 1.5 HP DPST would do a 1.5 HP motor
They may have the switch rubber boots in the same section, in Gardner Bender packages.
Packaged in pairs, it works out to $2 or less for the rubber boots.
WHOOPS!
Count is correct, that was a typo on my part. Double Pole SINGLE Throw for the off switch. Double Throw would be for the Forward/Stop/Reverse switch, but you should only need a SINGLE pole for that switch, IIRC. So DPST for on/off, SPDT for reversing. Make sure it's an On-Off-On for the SPDT toggle though.
As for the kit switches, they're not a bad option, though they can be a little pricey. I recently wired up a 1HP Dayton drive that's very similar to a kbac, and they wanted up to $50 + shopping some places for basically just a run of the mill On-Off-On toggle with three wires, and a 3 pin female jumper connector. Even the $35 that most places want for it is borderline ridiculous, IMO.
I dug through my parts pin and found everything I needed for practically nothing. Pro Tip: before you throw out old electronics, pull out the cables, connectors, components, etc... They come in handy if you like to tinker.
At any rate, the jumpers that KBAC uses are just your standard female spade connectors with rubber over them. They're available in most hardware stores, and you can get a small box of them for next to nothing.
