Keep leather sheaths conditioned
I'd imagine that a quality leather sheath should last a lifetime and then some if properly cared for.
What is the easiest no fuss way to keep them conditioned (enough moisture or oils to prevent them from drying out and cracking)?
I've used some Filson boot conditioner before, but was wondering what else you guys use.
I've also tried the search function to no avail.
Thanks
i use my lexol leather cleaner and conditioner. Same stuff i use on all my leather equipment. Saddles, boots, belts, etc.
SnowSeal has worked well for me. Seals the leather and inhibits moisture absorption, which can cause rust. Doesn't soften the leather either. As a rule I take the sheath apart and melt in the SnowSeal inside and out, then re-stitch it.
Try posting this in the new sheath forum. I'm sure you'll get a zillion opposing opinions on what works best.
I'll second the Lexol cleaner and conditioner for general maintenance and Aqueous Nikwax or Nikwax paste for waterproofing.
I use neatsfoot oil most of time but others like snowseal too sometimes. I most always heat the item in the oven for few minutes on about 300. Normally heat then apply then heat again. It allows everything to really soak into the leather. I always do this to my Filson hat too. I actually apply the Filson wax (what ever its called) then heat and it melts and soaks in well then I put in a cool place and it cools and the hat is like new again. :D I normally use neatsfoot and heat on all my GB sheaths and fb knife pouches also.
Has anyone heard of Brooks Proofhide? It's used on Brooks leather bicycle saddles. BF members should check out their website - even if they're not cyclist. Nice hard leather saddles with rivetted cosntruction. Most comfortable thing out there. Anyway, Proofhide is used to condition their saddles, which are meant to be kept firm, but mold a bit over time to your nether regions. It's a proprietary mix of beeswax, cod oil, and other stuff. Probably would be excellent, since it doesn't soften leather like neatsfoot.
