- Mar 8, 1999
We've all been told by the more experienced people on this forum to NEVER wrap your fingers around the part of the sheath that protects the blade's edge. They told us and told us the knife could cut through the sheath and slice our fingers. They even posted stories where a good whack with the blade still in the sheath cut the knife free of the sheath.
I don't know about you guys, but I'd read those warnings, look at my solidly constructed sheaths tightly held together with a leather covering and figure maybe that would happen to a sheath well worn from months of daily carry, but these are good and tight and new. No need to worry. WRONG, WRONG, WRONG!!!
I've recently seen three sheaths without a leather covering, just finished wood with thin brass strips around them holding the two sheath halves together. Listen up here guys, HI shop #1 is in southeast Nepal at an elevation af 2000 feet above sea level where according to Uncle Bill, the weather right now is about a hundred and ten farenheit with 98% or higher humidity. It's monsoon season. Uncle Bill's place in Reno is closer to 4000 feet above sea level and high desert with low humidity. Given time and the two scabbard halves dry, shrink a bit, get loose, and separate, leaving gaps along the edge where you can see the blade edge. Maybe on the leather covered sheaths the leather shrinks more than the wood, making it appear that the thing is still tight. I'll just say that having seen these three uncovered sheaths I no longer trust the leather covered ones, and I'm now listening to John Powell and Uncle Bill.
Uncle Bill asked me to note that two out of the three were not even HI blems but instead decently finished village quality.
The third is an HI blem, and it's scabbard has brass strips running the length of the blade spine and edge. IT's scabbard seems to be solid, but I can't see under the brass. I can't see under the leather of the leather covered sheaths either. But having had a chance to see the way they are all constructed, I can tell you that John Powell and Uncle Bill know what they are talking about.
SO KEEP YOUR FINGERS AWAY FROM THE SIDE OF THE SHEATH NEXT TO THE BLADE'S EDGE IF YOU WANT TO KEEP YOUR FINGERS, JUST IN CASE.
