- Jan 29, 2018
I bought these 2 knives in the past week. The Grip is on the left, Blur on the right. The intended use is EDC and I try to use the proper tool for the job (no intentional abuse for these knives)
Similarities:
- Both are Made in the USA.
- They are of similar size.
- They look pretty much the same.
- They weigh the same (3.90 vs. 3.82).
- Both are drop point blades.
- Both have pocket clips and lanyard holes.
- Both models can be configured in multiple variations (grips/steel/colors/etc.)
- Blur @ $57.43 (Amazon)
- Grip @ $102 (Blade HQ)
- Blur has Sandvik 14C28N black washed. Classified as "upper mid range" quality.
- Grip with 154CM satin. Classified as "high end steel".
- Blur is aluminum with rubber inserts,
- Grip is polymer with texture.
- Blur has the Speedsafe system.
- Grip is manual.
- Blur has a liner lock.
- Grip has the Axis lock.
- Both knives will shave your arm hair right off out of the box. I don't have any comments on edge retention as of yet.
- Both knives are tight at the pivot point and the blades are centered. I applied Blue Loctite to the clip screws and checked other screws and found no issues. I applied gun oil to both knives and the action is fine on both.
I really like the Speedsafe feature on the Blur. The blade opens with a slight push on the thumb stud. Now, the problem is that the Blur thumb stud is angled and sharp. I can see these thumb studs tearing up your pockets and/or hand. I actually had a file in my hand and I was going to file the studs down but I held off in case I think of a better solution. The Grip has thumb studs too but they are more rounded off and not an issue. You can easily "flick" the Grip open even though it is a manual knife.
I don't plan on beating the crap out of these knives so the blade locking mechanisms appear to be substantial enough for my EDC requirements.
The Grip is thicker than the Blur, which negatively impacts pocket carry so a certain extent.
I would buy both knives again if they were lost. The Blur is a really good value in that you could almost buy 2 Blurs for the cost of one Grip. The Blur thumb studs need to be modified though. I'm new to the Benchmade Axis lock system and just getting used to it. Blade unlocking with my thumb is a challenge since the unlocking mechanism is a little gritty. If you use your thumb and index finger to unlock the blade it is very smooth. Kershaw blade closure is a two handed operation.
Both of these knives should last a lifetime with proper care and use. You can't go wrong with either one of these. I am curious as to your thoughts and preferences on these 2 knives.
