- Mar 5, 2005
Cliff, are you saying Kershaw is misinforming people?
I didn't get that out of his post, please elaborate?
Rather a trend in general for manufacturers to run their 420hc, and AUS6, and AUS8 too soft, in an attempt to appeal to stupid people who misuse knives, by making blades less prone to break through lower hardness.
Which knives? The hardness has changed on these so you might have had one of the earlier softer ones. You can expect as much as a 5 point difference anyway from quoted to actual based on some of the HRC tests done on various production knives. This class of steel (low carbide) is actually designed for low angles, unfortunately most of the steels of that class (420HC, AUS-6A, etc.) are left really soft for "beater" knives, so people have really misinformed viewpoint on their maximum level of ability.
-Cliff
Under what conditions do you use a thumb ramp? Do you find it confers real advantages? As for myself I never understood why one would want to load the thumb like that instead of transferring the force to the palm.
... it may just need a few more sharpenings to get to better steel.
Hi, kel_aa. I find myself doing a lot of medium-to-heavy cutting where a knife with a lot of belly, and using a rocking cut, works very well. A well-designed thumb ramp not too far out on the blade like on the JYD2 allows force to be distributed from thumb through palm and heel of hand, which for me is a lot more comfortable and much less fatiguing. I only find this so on blades in this size range, on larger or smaller blades thumb ramps tend to be either of little value, or even a nuisance to me. Also I don't like sharply jimped/grooved ramps unless I'm going to be wearing gloves, so that limits the usefulness of some.Under what conditions do you use a thumb ramp? Do you find it confers real advantages? As for myself I never understood why one would want to load the thumb like that instead of transferring the force to the palm.
Cliff, how/when is this precise control utilized? Would you in your kitchen use it to core an apple/dig out buds in a potato using large 4 inch folders/paring knives? Would you outline a piece of suede to patch your jacket... detail a wooden figurines... carve a decorative flower out of a carrot or what not? Is that better than just choking up on the blade?Cliff said:Precision control of the point.
So say a TV with thick cardboard is sitting in your living room after you installed your 42" LCD. You have your 2.5mm thick folder and you want to section the cardboard to recycle. I conceed that it can be a strain on the area between the thumb and the forefinger using a hammer grip as it gets lower towards the floor. I will have to compare the saber grip to see if it might distibute the force better, rather than exchanging a sore thumb for a sore palm. Do you suscribe to the increased precision offered by Cliff, in preference over choking up?Dog of War said:I find myself doing a lot of medium-to-heavy cutting where a knife with a lot of belly, and using a rocking cut, works very well.
If I got a new 42" LCD TV, the box might just wind up stashed behind or under the sofa for months.So say a TV with thick cardboard is sitting in your living room after you installed your 42" LCD. You have your 2.5mm thick folder and you want to section the cardboard to recycle. I conceed that it can be a strain on the area between the thumb and the forefinger using a hammer grip as it gets lower towards the floor. I will have to compare the saber grip to see if it might distibute the force better, rather than exchanging a sore thumb for a sore palm. Do you suscribe to the increased precision offered by Cliff, in preference over choking up?
Yes.
This would depend on what you mean by low angle![]()
Ref :
http://www.bladeforums.com/forums/showthread.php?t=344902
On a curious note, most of the low carbide steels are really disrespected on the forums, the stainless ones anyway, the carbon/tool steels ones are well respected. This is kind of silly as they have similar properties.
-Cliff
Ask me what a "lower" angle is and I can answer that, ask me what a "low" angle is and I can't answer that![]()
