- Apr 3, 2001
I don't have a One-Ton, but the blade on the Half-Ton is actually a little wider than the Large Vantage. I measure 1-1/8" on the Half-Ton and 1-1/16" on the Large Vantage. I would expect the One-Ton would be larger and wider than the Half-Ton.
I'll echo mk.ultra's recommendation on the Kershaw/Emerson CQC-6K if you're open to other suggestions. Compared to the Vantage, the CQC-6K has, IMO, better ergos, better F&F, better edge retention, stronger blade (retains the full thickness of the blade stock for half the blade width), and wave opener (both functional and kinda fun). The Vantage has a lot going for it too - deep carry clip for discrete carry, thicker and rounded handles (fills the hand a little better), and a nice high hollow ground blade (makes it an excellent slicer).
Here's the CQC-6K next to the Large Vantage. I have the Large Vantage Pro, but I believe the only differences to the Select are the blade steel (S30V vs. 420HC) and handle material (G10 vs. FRN).
Wow that Buck is off center..... Does it scrape the liner?
