I wish I could find the review for you, but I do remeber a reviewer citing control issues, so be careful while you're getting to know it! Then post back with your review!
The Kershaw Outcast SUCKS! mine chipped with regular use, and then after a while longer the dumb little part right next to the butt of the handle broke off!(not full tang, btw, its plastic inside. Also, I thought the D2 steel would hold an edge for at least a little while, and it didnt work out. and my final gripe about the knife is that the clip (back part of the tip) was crooked for some reason. Major disappointment.
Sorry yours sucked so bad.
My outcast has seen more chopping than any other knife including my axe. Yes the factory edge was not that great but with a convex bevel its a cutting machine, edge retention has been very good with mine and even contact with rocks and dirt has only produced flattening of the edge. I have never had ANY chipping problems or did I ever feel like the blade was going to break. No its not a full tang but it does extend to 80% or 90% and is skeletonized.
I also stripped the coating from mine because it was causing it to stick in the wood when chopping.
What did you guys do to strip the coating?
Belt sander.![]()
