- Dec 19, 2002
Kershaw Scrambler A/O Folder, Blackwash 8Cr13MoV, Textured G-10/410 front,
410 black-oxide BlackWash Finish Bolster & Back Handle
Suggested Retail: $64.99 Our Price: $37.95 You Save: $27.04
http://www.knifeworks.com/kershawsc...oxideblackwashfinishbolsterandbackhandle.aspx
The Scrambler is a cool and classy knife to begin with. But now Kershaw has added an extra measure of cool with our BlackWash finish. BlackWash gives a knife that already-broken-in looklike a favorite well-worn pair of jeans. The coating also provides an extra measure of protection for the metal and helps hide any additional scratches you may put on the knife during normal use.
Designed by RJ Martin, the Scramblers drop-point blade is hollow-ground so it breezes through slicing tasks, while the large flat-ground top swedge adds to its good looks.
The blade steel offers strength and good edge retention. All the metal on the knifeblade, front bolster, and handle back are BlackWash finished. The comfortable, secure-grip handle features textured G-10 on the front side and a sturdy frame lock on the other. The bolster is extended to provide forefinger protection and to ensure the knife sits firmly in the hand during use.
The Scrambler opens quickly and easily with the ambidextrous flipper and SpeedSafe assisted opening. It includes a reversible pocketclip for left- or right-handed carry.
Specifications:
Overall Length: 7.875"
Blade Length: 3.50"
Blade Material: 8Cr13MoV
Blade Style: Drop Point
Blade Grind: Hollow
Blade Finish: BlackWash
Edge Type: Plain
Handle Length: 4.25"
Handle Material: G-10
Frame Material: Stainless Steel
Weight: 5.25 oz.
Pocket Clip: Right/Left Hand, Tip-Up
Knife Type: Spring Assisted
Opener: Flipper
Lock Type: Frame Lock
Brand: Kershaw
Model: 3890BW
Designer: RJ Martin
Country of Origin: China
Best Use: Everyday Carry
Casio G Shock Military Sand Series
Our Price: $110.00 Shipped in the USA
http://www.knifeworks.com/casiogshockmilitarysandseries.aspx
The Military Sand series introduces new beige colorways for our two most popular cases in G-Shock, DW6900 and GA100. Designed after camouflage uniforms worn in the desert, the case and bands are all in matte sand beige with dials and function labels in black. These... models showcase a new taste of military colors in both practical and fashion scenes. Resin band Analog and Digital watch with sand beige face with black highlights.
Shock Resistant
200M Water Resistant
Anti-Magnetic Structure
12/24 Hr Time Formats
Specifications:
Shock Resistant
Magnetic Resistant
200 Meter Water Resistant
Auto LED Light with Afterglow
World Time
29 times zones (48 cities + UTC), daylight saving on/off, home city/world time swapping
4 Daily Alarms and 1 Snooze Alarm
Hourly Time Signal
1/1000 Second Stopwatch
Measuring capacity: 99:59'59.999"
Measuring modes: Elapsed time, lap time, split time
Others: Speed (0-1998 units/hour), Selection distance input (0.0-99.9)
Countdown Timer
Measuring unit: 1 second
Countdown range: 24 hours
Countdown start time setting range: 1 minute to 24 hours (1-minute increments and 1-hour increments)
Other: Auto-repeat
Full Auto-Calendar (pre-programmed until the year 2099)
12/24 Hour Formats
Accuracy: +/- 15 seconds per month
Battery: CR1220
Approx. battery life: 2 years
Module 5081
Size of case/total weight
GA100LG 55.0 x 51.2 x 16.9mm / 70g
GA100SD 55.0 x 51.2 x 16.9mm / 70g
GA100 55.0 x 51.2 x 16.9mm / 70g
GA100A 55.0 x 51.2 x 16.9mm / 70g
GA100B 55.0 x 51.2 x 16.9mm / 70g GA100MC 55.0 x 51.2 x 16.9mm / 70gSee More
Specifications:
Blade Length: 3.50"
Blade Grind: Hollow
Edge Type: Plain
Weight: 5.25 oz.
Opener: Flipper
Brand: Kershaw
Model: 3890BW
Designer: RJ Martin
Shock Resistant
Specifications:
Shock Resistant
Magnetic Resistant
World Time
Hourly Time Signal
Countdown Timer
Other: Auto-repeat
12/24 Hour Formats
Battery: CR1220
Module 5081
