13c26 is almost identical to uddeholm AEB-L and its probably alot better than 440c. ive heard "as close to carbon steel as it gets"..
AEB-L is a stip steel made in Sweden by Uddeholm. Composition:
C Si Mn max P max S Cr
0.68 0.4 0.65 0.025 0.015 12.8
Few know what AEB-L steel is, and those that do, only have heard that it is similar to 440B or 440A. The only similarities between AEB-L and 440B or 440A is the amount of carbon. The fact that AEB-L has only 12.8% chromium by volume compared to the 16-17% in 440A and 440B makes the steels almost as different as night and day. This makes AEB-L very balanced, it still has excellent corrosion resistance, in the same area as 440C or other popular stainless steels used in knives today. It gets very hard, up to 64 as quenched. Though AEB-L is not a powder metallurgy steel, it contains very tiny carbides, its average carbide size is eight-tenths of one micron, powder metallurgy steels have a carbide size of 2-3 microns. This gives AEB-L excellent toughness, great ease of sharpening, ease in grinding and polishing, great wear resistance, and a very keen edge to a knife. 440C has carbides at about 50 microns. A very keen edge is about one half of one micron, so when cutting, carbide p ullout happens with large carbides, the carbides are pulled like a tooth out of the blade, this makes for a toothy and hard to sharpen edge, not to mention that the carbides are virtually worthless. AEB-L also naturally forms what is called the K2 carbide, the harder of the two chromium carbides, compared to the K1 carbide, which is formed in steels such as 440C. The K2 carbide is about 79 on the Rockwell C scale, compared to 72 for the K1 carbide. Through proper heat treatment, AEB-L has fine, evenly distributed K2 carbides. AEB-L lies almost perfectly on what is called the “Carbon Saturation Line”, which means that all of the carbides formed are precipitated carbides, not primary carbides like are formed in 440C, and there is more carbon and chromium in solution than 440C. Primary carbides are very large. So, through a balanced composition, AEB-L has excellent toughness, edge retention, workability, ease of sharpening, and ease of polishing.
http://www.devinthomas.com/pages/faq.html
sandvik 13c26:
C 0.68, Si0.4, Mn 0.7, max P 0.025, max S 0.010, Cr 13
