IABIGBUCKGUY
- Jul 7, 2011
I have 2 New Kershaw Knives for sale. Sorry no box with these knives. They both fire hard. Good flick.
Your choice $25.00 each TYD in the U.S. PayPal only.
KS1730SS: 1730SS Zing
Kershaw Knives
This iteration of the popular "first generation" Zings designed by RJ Martin.
What's different? First of all, this Zing is all stainless steel, from pointy tip to handle butt. Just smooth, sleek, bead-blasted steel all the way down. The blade is high-quality 8CR13MoV stainless steel, heat treated to Kershaw specifications to bring out the very best in the steelstrength, hardness, and the ability to take and hold a wicked edge. The modified drop-point blade offers superior slicing and utility capabilities.
To give this Zing even more, well, zing, Kershaw has added SpeedSafe assisted opening. Just pull back on the ambidextrous flipper and the blade moves out of the handle, quickly and easily. You can also access the Zing's SpeedSafe feature with a simple push on the thumbstud. Either way, your Zing is ready to go quickly and easily.
As a frame lock knife, the Zing SS is slimmer than previous liner lock Zings and rides even more comfortably in your pocket. The handle is drilled so that you can position the pocketclip for either tip-up or tip-down. And, of course, there's a handy lanyard hole. The Zing SS is a value priced, every day carrying knife with a clean look and lots of style.
Specifications
Kershaw Knives
High voltage looks and a slimmer profile. The Volt SS picks up where the Volt II left offand gets even better. While its larger than the original, its slimmer, features a solid frame lock, and is all stainless steel from tip to butt. Designed by RJ Martin.
Features
Specifications
Kershaw Knives
Specifications
- Blade Length: 3"
- Closed Length: 3.9"
- Overall Length: 6.9"
- SpeedSafe assisted opening
- Frame lock
- Flipper
- Reversible (tip-up/tip-down) pocketclip
- Steel: 8Cr13MoV, bead-blasted finish
- Handle: 410, bead-blasted finish
- Weight: 3.3 oz. (93.5 g)
- Made in China
Description
KS3655: 3655 Stainless Steel Volt Kershaw Knives
Features
- SpeedSafe Assist Mechanism
- Reversible Pocket Clip
- Frame Lock
- R.J. Martin Design
Specifications
- Blade Steel: 8Cr13MoV, Bead-Blasted Finish
- Handle Material: 410 Stainless Steel, Bead-Blasted Finish
- Blade Length: 3-7/16"
- Closed Length: 4-1/4"
- Made in China
