- Nov 29, 2013
Pictures here
Note: for paired knives, top knife in open pics = left knife in closed pics
Note 2: All knives are factory seconds/blemished, the blemish will be noted in the description if I can find it (on many I can't). All are new/unused, no boxes (because blems don't have boxes).
First up are the Elmax steel Knockouts. The blemish on the top one is a bit of color shift in the blackwash finish on the blade, visible in the lock-side picture. I cannot find a blemish on the bottom one. Centering on both is good, with lockup around 40% on the left/top and 50% on the right/bottom. Asking $105 net via Paypal each. Bottom sold.
Second are the Elmax Leeks. Blemish on the top one is a steeper/higher than normal final grind/edge (though likely within the grind variance I've seen on Leeks, which is large). The blemish on the bottom one is a more-stonewashed spot in the blackwash on the blade, visible in the presentation side picture about halfway down the blade. Centering is good on both, and lockup is around 25% on both (as is typical of linerlock Leek variants). Asking $60 net via Paypal each. Both sold
Third are the Snapon Leeks. These are one of several Snapon variants, this one is simply a standard Leek with the logo etched on (rather than the various colored liner lock variants). I cannot find a blemish on either, but the torsion bar on the right/bottom one is a little weak. Centering is good on the left one, the right one favors the lock side slightly but does not rub. Lockup is around 40% on the left and 50% on the right. Asking $45 net via Paypal each.
Last is a composite blade Leek, with D2 cutting edge. No visible blemish on this one either. Centering is good and lockup is around 35%. Asking $50 net via Paypal.
No trades at this time.
