I had a Schrade Little Bear (?) that I kept on my key chain ring so long it wore thru the bail. Sent it back to Schrade and they repaired it. Started traveling a lot and got to be a pain taking it off my key chain every time I flew, so now it is my knife drawer. John
Mini Champ
This is cool. Somehow, I wasn't aware of this model. It looks similar in overall size to the Leatherman Squirt. I imagine it's a tad lighter. I'd be curious to see some comparisons between those two choices in a key-ring role.
BTW, how do those tiny pens hold up? Is there ever an issue with leaking?
I've had both and for the last 7 or 8 years the Leatherman squirt has been my keychain multitool. A little heavier than the 58mm mini champ, but a lot more mission capability built into it. The small pliers/wire cutters and heavier duty screw driver push it over the top compared with he small Victorinox. And on the squirt, the knife blade is a better cutter with a chisel grind that gets shaving sharp and cuts deeper than the Victorinox blade. The squirt has a boxier feel in hand, lending to better grip over the small SAK. No tweezers but the pliers serve as small forceps.
With the squirt, I no longer carry a small SAK, and I was a die hard SAK fan. But the squirt is just a wider range tool.
Does the Squirt ever end up folding open on the key ring?
Same thing is on my keychain and has been for years!Serrated Ladybug. I almost always have another knife on me with a plain edge, so I went serrated on the keychain knife.
I carried the same Signature for about 10 years. I didn't use the pen much. The original cartridge/refill was still writing(!!) when I used it as part of the trade for the Mini Champ. It never leaked. I doubt the Mini Champ, which uses the same ink cartridge/refill will leak.This is cool. Somehow, I wasn't aware of this model. It looks similar in overall size to the Leatherman Squirt. I imagine it's a tad lighter. I'd be curious to see some comparisons between those two choices in a key-ring role.
What is this?wee little guy
What is this?
www.bladeforums.com
The spring that opens the pliers also keeps the tool closed. It's quite geniously engineered.Does the Squirt ever end up folding open on the key ring?
