Buy these directly from www.LCKT.BigCartel.com or claim them in the comments or PM and i'll send a PayPal invoice. Can also take money order!
These are a scaled down version of my BeerRambit multi tool to be used on a keychain or in the 5th pocket. They're 1/4" thick Brass and the bottle opening jaws also are a 1/4" wrench as well as holds the phillips bit driver housed in the body with rubber o-rings. The slot in the rear ring area can be utilized as a sort of pocket clip/dangler and work pretty good at keeping your tool ready to deploy instead of sitting at the bottom of your pockets.
Here are some specs:
Overall Length: 2.5"
Height: 0.75"
Thickness: 0.25"
Bit Size: 1"
Hex Size: 0.25"
SOLD OUT! There will be more in a week to two. These are $40 shipped on my webstore but you can get them for 10% off by using code "BF10LCKT" at checkout as a BladeForums member.
I also have a couple of my full size OG model BeerRambits which can be used as an impact device specifically for Silat/Kali. Do not use as a traditional knuck. These are also 1/4" thick
Specs:
Length - 4.5"
Width - 1.5"
Thickness - 0.25"
Ring Size - 0.95"
SOLD OUT! These are $49.99-64.99 but you can use the same 10% off code "BF10LCKT" at checkout.
Thanks for looking!
Ryan
LCKT
Height: 0.75"
Thickness: 0.25"
Bit Size: 1"
Hex Size: 0.25"
Specs:
Length - 4.5"
Width - 1.5"
Thickness - 0.25"
Ring Size - 0.95"
Thanks for looking!
Ryan
LCKT
