Who makes that parang?
It would depend on where I am at. If I will be in heavily-wooded areas, then a khuk would make more sense. If I'm in a mixed-area of woods, cane/bamboo and brush then the parang would make more sense.
Both blades evolved to perform under their relative conditions.
The khukuri tends to "dive" or angle downward when striking at horizontal angles. Therefore i think the parang is slightly better for all-around use.
I think that's a user-specific problem.
Bottom line is, everyone is different and some tools work better for one person than for another. The only way to be sure is to try.
I believe his point is that with a khukuri you can't chop "in a line".
How can that be anything BUT a user problem? It can be done just fine with a kukri, if one does like you say and adjust yourself to the way a khukuri wants to be used.My long-winded point being that it's only a user problem if you fail to adjust yourself to the way a khukuri wants to be used; but I think the "diving" nature of a Khuk is what makes it such an effective tool.
Also, efficient use of a Kukri tends to be more technique driven then many of the more intuitive chopping/slashing tools,
...it's a finesse tool that does not respond well to a ham fist-ed user, in fact it can be quite dangerous in un-trained hands.
<snip>
...with the Kukri, the weight and balance of the tool (that can vary widely between different Kukri styles) dictates how the tool is used;
...mostly you let the Kukri dictate how it's used.
I really did know what he meant, and I really do think it's a user specific problem. Your last bit:
Big Mike shows understanding when he said:
A kukri can be quite dangerous to someone who thinks they will just flail away with it. You really must get a feel for it (each one IS different), and how it wants to be used. If someone is not willing to learn to use a kukri the way it wants to be used, then kukri aren't for them. Seriously. I'm not being snobby about it, careless use of a kukri will result in getting bit -- they don't suffer fools -- and getting bit can mean grievous injury or flat out loss of whatever it hits. The reward for putting in the effort to learn to use them is you get one of the most, if not the most, versatile and useful woods/primitive living tools there is.
However, as I think I said earlier, you can learn to do just about anything with a parang that you can do with a kukri, but you'll never be able to outchop one, given the same length of tool. It's up to the individual which ois right for them, and both tools have centuries, possibly millenia, behind them to prove that they work. I can't call either a bad choice in general.
