Howdy all! I was fooling around with various blades I have when I started remembering about the tang breaks we had a while back. I tried the tests on several other blades I have. The first major fixd blade I bought (before I really knew anything about knives) was the SOG SEAL 2000. An intersting looking but rather ungainly piece with an almost square handle profile with enough checkering in the kraton to grate your hand into hamburger under strenuous use.
Anyway, the SOG flexed considerably under stress, and i believe (but didn't try it) that it might well snap under my full weight where, of course, most HI khuks would not. The SOG is also 440A stainless steel which is not renowned for it's strength and edge-holding, and then covered in some kind of enamel powder coating. With all teh recent posts about khuk's invulnerability, I thought "What the heck..."
I took out my shop 1 22" Ang Khola and chopped down on the flat of the SOG blade near the tang-blade juncture just in front of the handle. I used mainly the weight of the AK, not much additional force.
The powder coating on the Sog was neatly parted with just a small ding in the metal. The AK's edge was badly flattened just ahead of the sweet spotwhere the belly of the chopping area begins to curve up.
So next I chopped down on the spine of the SOG, using the same amount of force.
Bad idea. The SOG's powder coat was cut and the metal dinged just like before, but the AK's edge impacted badly. 1/4 inch wide 3+ millimeters deep rectangular notch punched into the edge. The metal of the edge was rolled and crumpled out to one side.
Then I chopped down on the edge of the SOG in an edge-to-edge impact. Very bad idea. The SOG's edge got a little v-shaped notch about 1 millimeter deep and maybe half that wide. The AK edge got a notch about three times that in size and depth with metal rolling out to one side.
I took a file to the SOG and reprofiled it's edge. Took about half and hour. There is now a slight "depression" from the stright line of the edge where I ground out the metal to get rid of the notch. Then I went to work on the AK with the same file. The SOG is noticeably harder, even though it is of the "soft" 440A steel. I did some reseearch on the forums, and some people have stated that SOG does use rather hard heat treatment on their blades to increase wear resistance, etc.
Reworking the AK edge took about 45 minutes and I had to remove a lot of metal. There is still a v-notch in the edge, but it is much smaller than it was. I don't really like it there, but grinding it away completely would significantly change the profile of the belly.
While my opinions of the SOG has gone up considerably, my faith in the AK isn't really as shaken as I thought it would be. The SOG is still very difficult to get a comfortable grip on.
Some things to consider:
1. SOGs are made in Seki, Japan, where they have state of the art furnaces and heat treat methods, computer controlled milling, etc. HI khuks are made by hand with hand tools.
2. The SOG was much harder than I thought it would be, but it also flexed rather more than I thought 1/4 inch thick steel would.
3. I believe, but I'm not sure, that BirGhorka is hardening their blades to a higher Rc than Shop 1 did. I didn't try my Gelbu Special on the SOG, but I ran the file over it lightly. It feels a bit harder than the AK, but that might be my imagination.
3. The AK, and most khuks, are strictly "agrarian" utility blades, i.e. choppers, diggers, etc. The SOG is expected to perform in a variety of conditions including being used to cut wire and other things SEALs do in their missions, while not rusting in salt water.
4. The retail price of the SOG SEAL 2000 is just about the same as a mid-size HI khukri, which is also about half again the size and three time the weight.
Moral of the story: HI khukris can chop through just about anything. Nails, concrete, etc. have been mentioned in various threads on this forum. However, nails are usually completely annealed metal (i.e.soft) and concrete shatters due to it's composite nature. A really solid chunk of igneous rock, like granite, would probably be the end of a khuk, but then it would also be the end of any other knife.
So don't worry too much. Your HI khuk can destroy anything in it's path that is animal or vegetable. And most things mineral. That is, as long as it's even a bit softer than the 5160 steel of the khuk. When a khukri meets something rather harder than it is, you will get serious damage to your blade. So if possible, have some idea of what you're cutting into before you whack away at it.
You may get an unpleasant surprise.
Tom
Tom
