Khukuri as a machete?
Alright, so I was wondering what type of a khuk would make a good machete if any. I've sort of figured it would be the Gelbu special or the Kumar kobra. What do you guys think?
- D
[This message has been edited by Vampire Hunter D (edited 02-25-2000).]
It entirely depends on what you're cutting. I have used a 20" Sirupati to clear a sloping riverbank of tall grass to launch a boat, and my shoulder was aching when I finished-my cheapo Barteaux machete would have done the job faster and easier, but I had room to take only one, so...
. OTOH, the machete isn't worth a darn for clearing woody brush, and the Sirupati makes short work of it.
Hopw this helps.
Seems to me the machete is a very specialized tool evolved to handle a jungle environment...the typical Collins or Tramontina machete is thin, to cut leafy or pulpy stuff; light, for all day carry and swinging; of soft steel that you can sharpen on any convenient rock; and above all, CHEAP. A 20" sirupati might do a machete's job for a few minutes, but any self-respecting Jivaro would trade it for a Tramontina after an hour of use. The khuk is much too heavy to do the job that the machete is designed and built for.( a very light villager sirupati might come closer to the mark, at a much higher cost.) Where the khuk shines is in cutting heavy woody stuff, limbing, digging and prying in tough resistant materials; and of course, as a weapon. gunhou
Cliff,
In an attempt to approach the scientific rigor of your tests, I took my 20" HI Shop 1 Sirupati and 22" Economy Model Barteaux machete to a pile of mixed dried brush I use as kindling, and chopped with a full overhead swing at about 3/4 power. The wood is mixed hackberry, black walnut and Southern catalpa, ranging from less than 1/4" up to 1" diameter. On the 1/4" or smaller pieces, there was no discernible difference in cutting ability - both easily chopped the dried wood. At larger diameters, the machete simply bounces off the wood, impacting it less than 1/4", while the Sirupati with its greater weight and thicker blade easily chops through with a single stroke. Additionally, the raised crosshatched texture on the machete's plastic handle rapidly becomes irritating to the hand when subjected to heavy impacts. On wood this light the Sirupati's horn handle is very comfortable, although its butt has been known to dig into the palm and cause some discomfort when used to chop larger diameter pieces for which it is not really designed.
Berk
20" Sirupati IMHO is the beast of choice for machete type work. For you guys who think that it's too heavy for this, swing a large AK for a while, and the Sirupati feels like a feather!!!(LOL)
Rob
Nothing soothes the nerves like a sharp knife in hand...
[This message has been edited by lefebvrj (edited 02-25-2000).]
Berkley :
Thanks for the details. Are you using the factory edge on the machete? I just got two Barteauxs (12" and 18") and the bevel grinds are very uneven and obtuse.
-Cliff
Cliff,
I am indeed using the factory "edge", if you can call it that. When I lived in the Virgin Islands some years ago, the local folks used files to sharpen their machetes. Do you think that is a reasonable approach to one of these, or should I use the more conventional methods used for khukris?
Berk
I would not leave them with the finish of a file as the edge would not be very durable. I used a file to do the rough profile on mine and finished with a fine DMT hone.
-Cliff
