Easy enough, I want a Khukuri for daily use as a tool. After tons of research I have more questions than answers.
Some background, I'm away from almost any form of civilization for 2-3 months at a time. I was/will be clearing sapplings of various poplar trees as well as elm and olive. 1/2 to 4 inch diameter with average being 2ish inches. The blade will also be used for slaughtering poultry of various types (mostly wild turkey) and chopping firewood in a pinch.
I know there are tools better suited for each task but this is what it will be used for when better choices aren't present.
Some basic questions i have are as follow:
Blade length for suggested use? Ive handled one with 10 inch blade and i would want a little more. I'm leaning towards 11ish inch blade length but seeking input from folks who have used this type of tool (13 seems common)
Full tang or hidden tang?
Will hidden tang be strong enough for suggested uses?
Will full tang disrupt weight/balance too much for continuous use? (When needed it will be used hours at a time up to daily)
Traditional or Americanized handle? Not true traditional as it is not comfortable from my experience with center ridge but same shape as traditional but smooth (no middle ring or ridge).
What overall weight (knife only)? Again daily use, hours at a time. Im thinking 1.5 - 2 pounds, again deferring to experienced users for more insight.
What type of heat treat? 5160 spring steel from 91 jeep is our stock.
Most importantly, what type of grind for listed uses? This will be field sharpened only using a stone or file for several months, so maintenance and functionality to consider.
Blade thickness, fullers and other features can be worked out once i have a general idea of overall specs i should consider. New to forum, granddaughter helped with the interwebs, sorry if i posted wrong area.
I'm not looking for this model or that model or suggestions on buy this or that or from this company or that company. Im simply seeking imput from more experienced Khukuri users since my knifemaker has no real knowledge of whats best for my needs (he make weapons not tools)
If anyone has knowledge to share, thank you!
