- May 28, 2024
Kiritsuke Gyuto S-grind 212 glossy
Kiritsuke Gyuto S-grind 212 glossy - Milan Tuma Knives
The Kiritsuke Gyuto is a combination of two Japanese knives: the Gyuto (the Japanese equivalent of the Western chef's knife) and the Kiritsuke (which is traditionally used for precision cutting in Japanese restaurants). This knife is characterised by a long, wide and slightly angled blade...
shop.milantumaknives.com
The Kiritsuke Gyuto is a combination of two Japanese knives: the Gyuto (the Japanese equivalent of the Western chef’s knife) and the Kiritsuke (which is traditionally used for precision cutting in Japanese restaurants). This knife is characterised by a long, wide and slightly angled blade, usually between 21 and 30 cm in length. The Kiritsuke Gyuto combines the versatility of the Gyuto knife with the longer and more pointed blade of the Kiritsuke allowing for precise and clean cuts.
The knife has a special ”hollow” cut, which gives it less resistance when cutting and thus higher cutting power. The main advantage is that the cut food sticks to the blade much less than with conventional wedge-cut knives.
The blade is made of Swedish AEB-L stainless steel with a high hardness of 60-61HRC. With this high hardness, the blade has an excellent and durable edge, but the knife must not be used to cut into bones or frozen foods, as this risks damaging the blade.
Knife type: Kiritsuke Gyuto
Steel: AEB-L
Hardness: 60-61 HRC
Total length: 347 mm
Blade Length: 212 mm
Blade thickness at the handle: 3 mm
Knife weight: 177 g
Grinding: S-grind / dutý výbrus
Handle: grenadil, alpaca, curly birch
PRICE: SOLDPayPal: milantuma11@gmail.com
Kiritsuke S-grind 189 glossy
Kiritsuke S-grind 189 glossy - Milan Tuma Knives
Kiritsuke, the universal kitchen knife for everyday use. The blade shape is similar to the Santoku knife, but has a higher and longer blade profile. The knife has a special ''hollow'' cut, which gives it less resistance when slicing and thus greater cutting power. The main advantage is that the...
The knife has a special ”hollow” cut, which gives it less resistance when slicing and thus greater cutting power. The main advantage is that the sliced food sticks to the blade much less than with conventional wedge-cut knives.
The blade is made of Swedish AEB-L stainless steel with a high hardness of 60-61 HRC. With such a high hardness, the blade has an excellent and durable edge, but the knife must not be used to cut into bones or frozen food, as this risks damaging the blade.
The knife does not require any special care, just wash with water and wipe dry after use. Sharpening of the knife is best on water stones, do not hesitate to contact me if necessary.
Knife details
Steel: AEB-L
Hardness: 60-61 HRC
Total length: 320 mm
Blade Length: 189 mm
Knife weight: 180 g
Santoku S-grind 158 Glossy
Santoku S-grind 158 Glossy - Milan Tuma Knives
The Santoku knife is a versatile kitchen knife that is popular for its balance, comfortable handling and ability to handle a wide range of kitchen tasks, both processing vegetables, meat and mushrooms. The knife has a special ''hollow'' cut, which gives it less resistance when slicing and thus...
Knife type: Santoku
Steel: AEB-L
Hardness: 60-61 HRC
Total length: 300 mm
Blade Length: 160 mm
Knife weight: 150 g
PRICE: SOLD
